2022 Colorado transmission not shifting right on 1-2 shift
Cranky
Banned Henchman #27
Staff member
12:59 PM
Pasadena, Texas
Seems to only do it when cold....dealer 'adjusted' something and it worked ok for awhile. Another Colorado did the same thing. No one seems to know what's up with it. Upon take off (cold engine etc) and it goes to shift into 2nd, it acts like it goes into neutral and of course, I automatically let off (pun intended) the gas and it then goes into second. From then on, it's fine. Anyone know what's up with that?
Is it temp related? Will it act up if you let it warm up a bit? Let me find a link to the Colorado website that has helped me a few times.
Is it temp related? Will it act up if you let it warm up a bit? That should be a 4L60 and the valve body is solenoid controlled. Let me find a link to the Colorado website that has helped me a few times.
[/URL]
It's usually fine after the first shift after start up. Just driving about 800 feet to the stop sign, it doesn't do it anymore unless the truck is allowed to completely cool down and even then, it's usually ok.
Not sure what your miles are but that has a 5 year 60k drive train warranty.
We have a 22 Equinox , only reason I know those numbers lol.
Not sure what's up with your trans, prob one of the electronic shift senders or the computer.
33k....but the dumb dealer is saying it's a 2021 because it was built 11/21. I asked them why is all my paper work saying it's a 22 along with a 22 owners manual. Not too sure about auto nation.
33k....but the dumb dealer is saying it's a 2021 because it was built 11/21. I asked them why is all my paper saying is a 22 along with a 22 owners manual. Not too sure about auto nation.
Did you tell them about the secret 10th digit of the VIN?
He's full of crap, 11-21 build is a 22 year model.
Anyway if it was a 21 it is still covered by GM on the 5 year 60k basic drive train warranty that comes with all GM autos and trucks.
Call a different GM dealer, I have no idea why they would be jacking around ?
Warranty work is good for the service dept. It's money in the bank.
Does it 4 forward gears or 6? I ask cause the 6l80 has problems and I heard something about a class action lawsuit against GM.
They won't do any warranty work for that problem, the service bulletin already states that "Replacing transmission components or complete assemblies will not improve the condition."
Well that sux.
Sounds like the dealership is stalling, is there another dealership close by?
If you bought it brand new, I would check out the lemon law.
Well, it if craps out right after the warranty expires, I'll look into that. She likes my old junk but not sure if the old junk will like her lol
Not familiar with that specific trans,
does it have a speed sensor/s on the trans ?
could be something simple like that & overlooked
computerized stuff is weird or more hard to diagnose,
if they don't know the stuff, or just too lazy to do the protocol,
research/diagnostics, plug into the OB2 port, for codes
I wonder if there's an update for the computer/flash a new program
most GM trans that had computer aid, can be flashed/changed
a good dealership, good service writer/shop mngr & 'competent tech' should know
Or buy/get a aftermarket programmer/flash it with a upgrade/performance deal
(if it's not locked out so you can't work on your own, BS govt. EPA/C.A.R.B. crap)
or use an OB2 reader, & *see what codes pop up or needs to be cleared,
the *latter should tell the story, how you interpret it, to fix it, is the other part
do a trans fluid & filter (maybe partially clogged ?) change, both,
maybe a flush (?) too prior, it's not that tough
it won't hurt it w/33k miles either, it's almost due anyway
use the right fluid
I'd also wonder if line pressures are off, or a band adjustment (don't know the trans)
or when cold the front pump, not keeping up takes a bit to catch up
sort of like the old 727tf need to check it in neutral,
so the pump is fully working
or when sat for a long time after it's 1st fired up
need to put it neutral to get the converter full & pump working correctly
before taking off
