I'm parting out a 5.9 Dakota RT and had planned on keeping the posi rear but a 6 lug? Is it worth keeping knowing I'll have to source 5 lug axles? My Mopar rear axle experience is pretty much limited to 8 3/4 so any suggestions are welcome.
the rear you have is a 8-1/4,albeit with 6 lug axles.
the trick,is to swap that chunk into a b body/m body/f body or later 8-1/4 Housing,
and using the b body/m body/f body axles and brakes.
it is indeed worth selling or keeping.
side note,while it is unique to find a l/s in a dakota,
they were super common in the durangos.
most all are 3:55 gears,check the glovebox to make sure the l/s code is there.
My mistake, should know better by now lol.You made me pull this one out? Sigh...
I did that with my 440 Dart love that 3:55. You just have to remember the ring gear has different bolt positions than a stock 8.25. Just FYIthe rear you have is a 8-1/4,albeit with 6 lug axles.
Thanks, this is what I needed to know. I'll salvage it and tuck it away, I just hate keeping stuff I'll never use.the rear you have is a 8-1/4,albeit with 6 lug axles.
Well this is an RT with a 5.9, a lot of motor for a little truck.Believe it or not I have never found a standard Dakota in a u-pull with a SG.
Never.
I have seen literally hundreds.
Durangos with 3.55 SG, yes, but never a Dak unless it was an R/T.
In today's world light has a different meaning. My Cruze with a 1.8 weighs 4,000 lbs so by comparison a 5.9 in a vehicle weighing the same as one with a 1.8 is light plus these newer motors are no slouch.When my Dak goes to scrap you can get the SG from it.
Dakotas may be small but mine weighs 4000 lb.
