Yeah, then I'll need some shorter bolts too.Yes it should, problem is the bolts are about 3 inches long and you will need to probably pull the radiator.
From the title of this post, I thought the OP really really liked 318 motors.
Exactly!Nope, I doubt rad will need to be removed. Shove some thin wood or cardboard between the rad core & fan to prevent core damage.
Loosen fan bolts 3 turns. Hit spacer with plastic hammer or block of wood to loosen it.
Remove bolts & lift out fan & spacer as an assy.
