As for the air cleaner, should we be looking for the orange 340 dual snorkel air cleaner or the earlier wrinkle black 340 air cleaner that was open all around at the bottom with no snorkels?
Yes, IDK if it’s available through MoPar anymore. But you’ll need the windage tray, 4 main cap bolts that are drilled on the head to accept 4 small (1/4 X 20 IIRC) attaching bolts that secure the windage tray...
Yes they are and it’s a goggle search away. Milodon also has there version and IIRC, replacement type bolts for this. Be aware that they have studs which are different in here requirements so steer away from studs. Just get the bolts. The small bolts can be hardware store bolts. Lock tight and hem in with the blue compound.Thank you rumblefish360! I have found the LA engine windage tray at Classic Industries and contacted them. They said the four drilled and tapped Main Cap Bolts needed to mount it are not included. Do you know if these Main bolts and the smaller windage tray attachment bolts are still available anywhere?
