Cliff Ramsdell
Engine has been run with this combo and no signs of piston/valve contact so all good about that. Now I have found that cam is 4 deg retarded and I want to change that to 0 deg so will have to check clearance again after that. Anyway, how can pistons be "leaned" to the left?
Good point about the banana cuts, will look for them! The non locking OEM has already been changed, but thanks!
I misread the original question. I thought it was left to right bank and not left to right side of the piston in the bore. Maybe the piston rocking in the bore, don’t know if have ever seen it like that though. Once apart look at pin and bushing wear that would allow the piston to move that way.
Cliff Ramsdell
