wyrmrider
just pulled up the Lill red express specs 78 detuned in 79 355 9 1/4 rear end rear end 8.2 compression windage tray no serial number on rt side of block
no cats 850TQ PD intake manifold 252-252 mopar degree cam overlap mopar 33 degrees (compare with other mopar cams)
68 340 cam regular spec is near 276 .484 lift and 48 degrees overlap from one source but I don;t think so red stripe valve springs no rotators
another source says 268-276-44 cam
Engine code EH-1 225 net hp @3800 this was a sandbag cus it put out more than that at higher revs 295 ft lbs at 3200
hemi mufflers with crossover 2 1/2 inch pipes
1.88x 1.62 valves mopar wicki says forged crank- Ive never seen one
wiccki says 440 valve body and 9" 2500 stall converter- never seen one of those either - anyone else?
IMHO "super heads" refers to the W2 on the prototype- I've only seen standard production "selected crankshaft"
340 cam, 3:55 gears and a looser converter would almost work in an 8.2 compression motor
HRN says 8.4 cr wheras E58 was 8.0 74 360 piston PN 3780071 someone can check the spec
