383 rough idle very low vacuum
josephqatarcarguy
9:48 PM
Qatar
Hey , my superbee which should have a mostly stock 383 engine has a rough idle and dies in gear . The engine is stock except edelbrock aluminium heads , firecore distributor and ecu , edelbrock avs2 650cfm carb , it has really low vacuum 5 ..6 .. I can get it to idle but the engine js vibrates alot , the idle mixture screws do nothing if adjusted , can turn it all the way in and the engine still runs , vacuum leak ? Timing is at 14 initial
What should I check?
Thanks guys
You already have a post started with the same question.
