The gear multiplication does make a difference. Look at the numbers:
1968 Road Runner
727 1st gear 2.45. 833 4 speed 1st gear, 2.64? Axle gear of 3.55 to 3.91. Multiply the axle gear by the 1st gear and second.
727/2.45 X 3.91 = 9.57.
833/2.64 X 3.91 = 10.33. Now consider the gear ratios of the new stuff. They shuffle around a bit. The A/T cars often have a 3.06 diff and a 4.71 1st gear. 3.06 X 4.71 =14.41 ! The 6 speed manual uses a 3.90 diff and a 2.97 1st gear. 3.90 X 2.97 = 11.58.
The gearing gets the car moving much quicker.
The gear spacing in the 5, 6 and 8 speed transmissions is so much closer and better.....
I race "stock" musclecars with my Caravan. I've beat more than one.
Car's of the late 60's were way ahead of any car from the 50's!It’s all about the engineering. Hi tech vs 1950’s tech. Multi port fuel injection, computer adjusted optimum air fuel ratio for rpm, load, and weather, roller can, variable valve timing, transmission gear ratios, etc, etc.
It isn’t right but it is so.
I always liked to tune for consistent performance in any kind of weather since I bracket raced most of my street rides. It's always nice to be able to go out to the track, run one time trial and it would run what it did last time out when the weather was hotter or even cooler. Then all I had to do was try and cut a good light! My old high 10.60 would run 10.50's with tuning but with two inline carbs on a TR, heck with messing with that! I could change my dial by leaving at an idle vs stalled up to 4500....and even then, it only changed .01True, and the fact that it will vary the mixture to compensate automatically...
Amen!Certainly there are many aspects to the hobby for people to enjoy well beyond performance. Arguably the majority of enthusiasts don't prioritize performance. But I believe that there are still a few guys around like me that do care about the performance of their muscle cars. All of the other attributes of these cars rings hollow for me if there is a lack of performance. If all there was is cruising around and getting thumbs up from passes by, and going to car shows and talking about some hard to get window crank, I'd sell my cars right now.
I'd stick my neck out to say that the new stuff probably has LESS parasitic losses from flywheel to tire than the old stuff. I'll bet a 376 HP 5.7 makes a greater % of net HP than a classic does.
And you would be absolutely correct.
I wish I had the actual data in front of me but I have seen dyno sheets of stock late model cars as well as classics. The net/Wheel Hp numbers on late models seem a lot closer to the flywheel rating compared to the classics. Now, some of this could be attributed to exaggerated HP claims of old engines, also you can factor in that they were GROSS rated.
