Sweet5ltr
Do you have any data on this? It would be interesting to see. It makes sense that there is a lot of effort by the auto makers to eliminate theses losses as much as possible and probably have come a long way, but the flip side is 8 speed autos would have more parasitic losses over a three speed by their nature, I would guess.
Yes & no, as the 6.4/392 is rated at 485 (NET) HP and the M6 Challengers regularly dyno around 430 RWHP. That’s around 12% drivetrain loss.
Most don’t consider NET HP rating differences when talking about 440’s, everyone says ‘375 - 390 HP’ but that’s not necessarily true, in reality, the only power that matters from an engine output term is NET (with all accessories attached and exhaust system). Now, compare the 485 HP 6.4/392 to the 1972 440 6-pack NET figures at 330 HP.
290 RWHP would be a similar drivetrain loss figure, and that is fairly accurate.
Now the difference is most likely with the 8HP70 transmission, as the drivetrain losses are minimal over the TR-6060, nearly identical along with having a much better gear ratio spread. TF-727 on the other hand, we know, has much more than 15% drivetrain loss, typically well over 20% and the gearing leaves a lot to be desired. People don’t really think about the big picture, the reason the GEN III Hemi cars run well is the Eagle & Apache heads with modern intake / cam profiles. Throw a great set of heads (TF 240) on a B/RB with the basic upgrades and not worry about a modern SRT. Engines are just air pumps, modern GEN III Hemi heads flow over 300 cfm, B/RB heads are lucky to flow 215 cfm.
