moper
Comp XE262.
don't worry about the factory rockers. the 1.38:1 stuff is B.S. the 272 will set up nicely with stock valve guide height and will work with stock magnum springs and seals. the only issue I can find with magnum springs is that I don't believe they are being reproduced anymore. the crane 99839 spring is a good substitute, fits stock retainers; but might need a little shimming to get to the recommended 1.80" installed height.Thanks to Everyone who chimed in. Its power disc brakes, will have fresh 727, undecided on converter. I thought the factory numbers were lower, but looks like the 272/455 sounds like the way to go. Using 68-70 HP ex manifolds. I'll stick with the 3.23 ratio. Will I lose that much with the factory rockers, or does it pay for a true ,1.5/1.6 adjustable? Think I'll send the block in for good measure.
i'm pretty much over .904 tappet hype. we can thank hughs for this. the first ".904" tappet cams he sold were engles "904" profiles. while I like engle stuff they still weren't as fast as comp XE or HL profiles. there's a difference between wanting to drive your car a lot or race it a lot. wiping a cam is worst than crapping the bed; expensive mess to clean up!I don’t call them Chevy cams but I do call them slow *** ramp cams.
They will still increase the power. The idea of taking advantage of the 904 lifted on mild mills is over rated. Yes it makes more power but not to the tune of what many say is worth it vs. how it acts.
Not every build requires the fastest rate ramp cam available.
Well, yes! That is a mess! LMAO!i'm pretty much over .904 tappet hype. we can thank hughs for this. the first ".904" tappet cams he sold were engles "904" profiles. while I like engle stuff they still weren't as fast as comp XE or HL profiles. there's a difference between wanting to drive your car a lot or race it a lot. wiping a cam is worst than crapping the bed; expensive mess to clean up!
Wooo, spec’d data, love it. Can you match it to others of similar grind/intake intentioned cams?I believe you and thanks- any more data ?
and yes the intake has a lot more area than the very lazy Magnum (which does rpm and wear well)
good example on why not to use MOPAR advertised durations and compare them with .006- like comp
the 256 @006 cam I use also has over .300 lobe lift and about the same at .050
20 degrees shorter duration - lets say evenly split between opening and closing means that I can get the valve shut 10 degrees earlier ABDC
(all depending on where they are installed)
but why it works good on the lower compression engines without giving up much when reved up (and obviously not for a 10:1 motor)
which one works best depends on compression, etc
The Magnum cam dies on low compression 400's even at highway speeds with stock gears- you have to hit kickdown to get a 440 cordoba to accelerate
The Magnum 268 is over 270 @.006 so I try and go less on less than OEM Magnum compression and make it up with better ramps and rocker ratio
thanks again
