GrabberOrange69
I'm building a 451 for a member here and we went with SRP's set at zero deck with a cut down 440 crank and 440 LY rods. You asked about rod length so be prepared for this thread to go to 5 pages! LOL. Some will say short rod and some will say long. I say Chrysler had it figured out pretty well and the result was time tested and it works so I went with the standard ratio of 1.80:1. Thinking back I probably could have gone with the lower ratio 400 rod without any ill effects, or for that matter any drastic improvements. I'd like to know if someone can tell the difference between the 1.696:1 vs. 1.802:1 rod ratio engine by driving it. What does make sense in this build, and something that might actually be measurable, is the drastic weight reduction to the reciprocating assembly.
Now to cram 470 cubes into that short package would require a short rod and result in a very low R/S ratio. Too low of a ratio might play hell on the thrust side of the piston and scrub off power due to friction. It is also said that low R/S engines don't rev well and tend to "vibrate" at high RPM. Mechanically speaking I think there is a point of ideal R/S ratio to balance torque and component wear. Again, the engineers knew something back in 1958 when these things were designed. The R/S ratio changes the torque of the motor and can be very beneficial to be on the low side if you want a tractor. A lot of newer engines run low R/S ratios probably for the torque reason but they are not of a 1958 design either. Note: The engine in the Honda S2000 has a R/S ratio of 1.82:1. It also has a red line of 9000 RPM!
PM sent to you MeepMeep
