It’s because you think the carbs will discourage a crazy amount of fuel but this is not how carbs work. They work on the draw of air rushing past the choke, boosters and on down which picks up the fuel to mix.
This is where “Jetting” the carb comes into play for any carb. If the jet is way too big, even on a 2bbl., you wash the cylinders down with fuel. The reverse is true with to small of a jet n any carb not delivering enough fuel causing havoc.
The engine will draw in what ever amount of air that is needed at what ever rpm it is turning at and as long as the fuel is metered to be enough, not to much, not to little, the engine will be fine.
The real question here is drivability with larger carbs.
Also, part throttle and wide open throttle.
If the carbs are tooooo large, then jetting can be a nightmare and a good smooth running engine without issues is the concern.
There is a lot to unpack behind this. But! A stock 413 can handle twin 600’s. While a smaller set will have improved throttle response, drivability & probably mileage if you can keep the foot out of it. This is why Edelbrock recommends twin 500’s calibrated for this.
I don’t think it’s a bad way to go BUT IF you need to save a few bucks and/or have twin 600’s on hand, use the 600’s.
