INTMD8
Very nice! Sounds like it has great throttle response!
It does! Thumbs up on the recommendation
Runs pretty good so far, just changed to lighter metering rod springs, set idle speed and adjusted idle mixture. Will dial it in on the dyno in the spring.
The AVS2 steps up a bit at the air cleaner stud so I'll need to either raise or remove the bridges on the air cleaner base.
Also, the ports on this intake are raised a bit in comparison to the stock hemi heads. I used Cometic C5598-047 (.047 thick) gaskets instead of the stock thickness .060 which dropped it down a bit. Port floors then lined up perfect. Top of intake port was about .025 above the port on the head which I thought was OK for now.
I plan to pull it apart at some point to do a roller cam and head porting and I'll match it then.
