Curiousyellow71
If you are use to specs for a hydraulic to compare it to a solid @.050 you need to add roughly 8-12 degrees to the solid....depending on how much lash the cam runs. So a 240 solid will compare roughly to duration to 230 for a hydraulic to perform similar. There is more too it obviously but it's a decent way to compare cams.
For the rocker ratio...the total lift is the cam lift times the rocker ratio. So if you cam has is .35 lift your opening your valves .525 with 1.5s vs .56 with 1.6s. You also gain a couple degree with the higher ratio rockers because your opening the valve quicker...but only 2 or 3 degrees at .050. If you look at hughes they list the lift for 1.5s and 1.6s on the their cam chart. Lift is for the most part free hp...but their is more strain on the valve train and when you go to a different rocker ratio the fulcrum moves on the valves causing geometry issues...the roller tip no longer hits in the correct location and you have to buy a shim kit to correct. Factory mopar ran 1.5s so they shouldn't need much of any shimming...where 1.6s definitely will.
Hope that helps.. on some threads wyrmrider mentions a rocker shim kit right up from B3racing I beleive. I dont have the link...but it's a good read.
