66Satellite47
Stroker kits today are so inexpensive and good quality, hard not to go that way.
I got a 440 built very similar to this, just a difference in cam spec. Your on the right track for a very strong and streetable 440.He has suggested JE SRP pistons and Eagle H beam rods. Also looking at a Comp 21-224-4 cam using Hylift Johnson hydraulic lifters. Using Clevite bearings.
I am on the list for Eddy Performer heads. Will be using adjustable ductile rockers.
Very true. My Coronet 440 motor I went with the H beams, race bearings, arp hardware and so on because of the 871 setting on top, Blowers tend to create more stress on internals. My Cuda 440 not supercharged but built healthy has an easy 500 hp with factory rods and crank, been together for years with no problems.I built several 440's over the years for drag racing, although they would have been pretty darn good as a hot street motor. If you just use stock 440 parts, steel crank, LY rods shot peened with good bolts you can make 500 HP and live for a very long time if you keep the RPM below 6500. The better rods and crank are good for more RPM. If you're going that way a stroker is the same price.
I'm not a very big fan of Mahle pistons for a street engine, Yes I totally would agree they are the lightest pistons but at the same time they have no skirt and they wobble in the bore, seen and heard a few strokers with Mahle's sound like a bad diesel at startup and when we called Mahle the tech guy said "Well it's the nature of the beast with hardly any skirt it wobbles in the bore especially cold", I really like ROSS pistons especially for street engine
It's a Long read.... but here is a link to a few inexpensive NON-Stroker pump gas .030 over 440 builds we did a few years back... complete with Dyno Sheets when completed.
Pretty similar to what you are looking to do.....
Hydraulic Flat Tappet Cams, XE274H and XE284H, 500-550 hp and 535 to 565 Ft/Lbs
simple...cheap... easy.... and absolutely NO piston slap 'noise' quite common with shorter piston skirt Piston Stroker's these days ?
The 440's are tough to beat.
http://www.dodgecharger.com/forum/index.php/topic,106687.0.html
the only caution today would be parts availability and the absolute epidemic levels of poor quality Flat Tappet Cam components ?
Thank you for all your work in this post, the build specs, and different dyno numbers. The read was great and just what anyone doing a lowly 440 build should see. I’ll being going through it many more times as I am not good at reading retention, at least that’s what my teachers used to say.
I wonder why flat tappet cams are at high failure rates? Any ideas?
That for sure, and also the fact that there seems to be a higher incidence of production defects....lobes without the proper taper, flat lifter bottoms, too much casting flash left between the cam lobes, stupid stuff like that....and that's merely what I've seen as a DIYer.Lotsa theories out there....
IMO.... Metallurgical deficiencies in the Chilled Iron Lifter Bodies (from China).... NO Wars wanted, but that's my opinion.
Call Dave Popp down at Topline Johnson... INSIST on getting U.S. made products !
or ?
you aid the Chinese in taking out what remains of our North American Economy without ever firing a shot(just send over a bug)
Do you not trust your engine guy? Sounds like he already made a recommendation..they can get a little testy when you overrule their recommendations with stuff you read on the internet..
Considering how many Mopar engines I've seen built that were absolute lazy pigs I prefer to know whats going in my build...
As Ronnie use to say "Trust but Verify"
or ?
Challenger, if you are reacting to my post #34, I should clarify. My "builder" did not do all his own machining, he had specialized machine shops that did specific things for him that he trusted, Then he checked each part for conformance with his quality expectations, which were very high. For most customers he did all the assembly. For me, he guided me through each step and showed me how to assemble a "race" motor. In my opinion the results spoke for themselves.
Edit: I'm not a builder, I am an assembler.
