wyrmrider
let's get clear
you can make great hp with an open chamber head as long as you keep the rpm above the torque (BMEP) peak
example: some stock classes
what sucks is on the street performance
I just do/did not build open chamber builds- go elsewhere except trailered cars
but then I do not run summit cams except for sale to used car dealers- but it is a better choice than a stock cam
never had a problem with valve bounce but I use asymmetrical lobes with carefully controlled close and the proper springs
The templets were for the earlier heads so BVVC with452 and similar- they work best with 902 and 915
now if you are building with a .050 down the hole and open chamber you have to back off on the compression and timing
problem is when you go to a thicker gasket and lower the compression you end up with the "use more throttle and make more heat" syndrome
so the temptation is to lower the compression even more
exactly what MOPAR did from 69> 73
Did not work then and does not work well now
but if you are on a tight budget you have to do what you have to do
Hints
minimize overlap and do not open the exhaust early- keep the valves on the seats as much as possible to keep the valves cool
do not lug the engine, keep it revved up when on the gas
no hot spots with open chamber???
The Plug is way down on one side and the other side is a long way off- the whole far side of the chamber is a hot spot
The flame front has to light a pancakeproblem is the far side lights itself
visualize the open chamber from the side at tdc
It is not pretty
Hints
It is not pretty
