383man
383man,
Do you use the 440 EZ (270 cc) or the 440 EZ-1 (275 cc) or the "Little" EZ (295 cc) heads? Also, are you running a stroker kit to get the 493 cid? If so, is it a 440 source kit? Final question, what is your complete set up that gets you into 10.76 @ 124.49 in that fine machine of yours?
Its the basic EZ head the 270 but we opened them to Max Wedge size. Yes it is a 440Source kit that has been in the car for almost 3 years and never any trouble. Its the 4.15 crank in a
.030 over 440 block. I use a solid flat tappet custom grind came thats .584 & .592 with 264 and 270 at .050 and the LSA is 110 and I have it in the eng at 106 ICL. I do use 1.6 Hughes rockers for a total lift right about .630. I had to use the dished pistons to get 10.6 comp and its only dished on one side so I still have quench. Up top is an Indy dual plane intake and a 850 DP. TTI 2" headers and 3" pipes out to the rear bumper with a X-pipe and Ultra-Flow mufflers. 727 I built with a Dynamic 9.5 converter that will flash about 4200. It has 4.30 gears and I use Hoosier radial slicks that are 30 x 9. Suspension is stock other then SS springs and 90/10 shocks up front. I still use the stock gas tank with a 3/8 sending unit and 3/8 fuel line. I also installed a 6 point rollbar. Car weighs just over 3700 lbs with me in it. And of course my best et so far is 10.76 @ 124 and thats thru the pipes on 92 pump. In fact I have never uncapped it or had racing gas in it. Thanks , Ron
