PP1RT
Get some of those u haul blankets to protect your paint. If you decide to go headers later you will likely have to lift the motor some when you install them. Leave your front pulley off to gain a little room in front.
If he leaves the pulley and water pump off it will help a lot.Get some of those u haul blankets to protect your paint. If you decide to go headers later you will likely have to lift the motor some when you install them. Leave your front pulley off to gain a little room in front.
First one i ever did was with tractor and loader. Motor,trans and headers bolted up all in one shot with the neighbors tractor out in the lawn. People told me it wouldnt work with the headers bolted up but it did. Manual steering maybe helped that.If he leaves the pulley and water pump off it will help a lot.
Have even installed them with a tractor and loader. Backhoes
I placed many a 350 Chebby and a couple 318s. I've always done it as you say. I wasn't sure if the threads on the aluminum intake on the 440 would handle the weight.
It does sound much easier to install the rocker assy and intake onto the motor while it's on the engine stand. Although this motor give my stand all it can handle.
Rockers are crane 1.5cap the back of the trans with a spare yoke if there is tranny fluid in it
lot's of good suggestions
did you degree your cam? easier on the stand
what rockers?
cam have stock base circle or do you need longer pushrods? do that first too
spin that oil pump with a hex shaft- check the rotation - to pre oil the motor- after you get your filter on
if headers you most likely will have to lift the motor- again
Degree'ing the cam is just the method of checking how it's installed relative to the crank..so you know exactly how things are timed. Cam timing could set up to be advanced or retarded a little, if desired..helpers always seemed to be unavailable for dropping in engines, I have always put at least 1qt ATF in the converter, bolt the trans to the block and adjust the chains so the trans tailshaft points down some and slide it in..I put a jack under the trans to level it. Jack a little, lower the picker a little, repeat... and it settles right in. Hopefully your shop degreed the cam on install, that's best time to do itRockers are crane 1.5
Know how pre-oil but not sure what degree cam means. Engine long block was assembled at machine shop and it at TDC with #1
I dumped some Dex/Merc in it before I realized what I was doing.If there is no fluid in the trans ATF4. Would go that route even with fluid in it.
Oh no!! It's done for even before you start it up!!I dumped some Dex/Merc in it before I realized what I was doing.
You have +4 dated to the 1980s where did that info come from? Around here had to go to Chrysler even in 2005 to get ATF+4.727 is very tolerant of trans fluid I'd avoid Type F like the plague and also Dex VI which Ford Merc- but it should be OK finish fill with type 4+
the later trans are built with much closer tolerances and are clutch to clutch shifters not clutch- band and they have lock up converters
I posted this B4 your last post- hope it helps
you asked about Trans fluid
The OEM from the 50s early 60's fluid was Type A Sperm Whale Oil
Then GM Dexron all long obsolete
GM does not support Dexron III any more so there is no standard for quality control- lots of cheap crap out there
MOPAR type 4+ is your best bet
It is licensed and the additive package is licensed so if it says 4+ it's a Synthetic with a super premium additive package- much better than Dex III
DO NOT USE DEX VI or later FORD MERCONs
your seals will not like U DEX VI even ate the seals on early 4L 60-80 GM trans till they changed the seals/ thrust washers
The absolutely best ATF is CITGO Quatrosyn It is a group IV-V base Synthetic whereas the earlier 3+- 4+ date from the mid 80s and these base stocks were way too expensive- 4+ was a cost effective solution to the problem of lock up life- synthetic base III based (3+ was group II based)
see
https://www.allpar.com/mopar/transmissions/fluids.html
and the SAE paper
incidentally those of us who also have GM or FORD products the CITGO Quatrosys is best for Everything except Type F- even Volvo and Nissan, and hydrobost etc
I put my 68-69 HP exhaust manifolds on my 440 in the 64 Dodge. Driver side not to bad, but surprisingly the passenger side was a major PITA. Scratched my newly painted inner fender wells.................................MOHaven't decided on exhaust yet.
I figured on installing manifold or headers after the fact
Some of the links I posted tell the history of post Dex fluids better than IYou have +4 dated to the 1980s where did that info come from? Around here had to go to Chrysler even in 2005 to get ATF+4.
