440 ?s
I'm fortunate. Here in the Midwest there are no shortage of Napa, O'Reillys, AutoZone and more farm supply stores than you can shake a stick at.
That because we by lots of parts. Is amazes me how fast those NAPA points build.
Napa pts. Are them bastards holding out on me?
They sure charge enough for some of their ****.
I only buy filters once a year and it's now.
Some of their filters are outrageously peiced
We have a filter sales month at one of the local stores with some decent case prices. 80% of whats here uses the same filter.
IDK what the licensing arrangements are for 4+
I do know there are very few actual blenders
everyone else rebottles
the additive source and the base stock sources are also controlled- you can't buy the additive pacage
More ?s
I just primed motor with this awesome tool that I should patent. :moparsmiley:
1.- When oil comes out your Rocker Assys, is that Sufficient?
2. - I'm about to install Valley Tray, Intake Manifold, and Valve Covers.
What sealant is best? Aviation? Black Stuff? Or a combination?
I use Hylomar except where the FSM may say to use something Else
I usually use anaerobic gasket maker instead of silicone- which is way overused on many motors I tear down
More ?s
Roll the motor over by hand a 1/4 turn at a time to make sure oil gets everywhere.
I was going to mention that 4+ is kind of hard to find....but wal-mart has it.
Cranky beat me to it.
"Like a Glove"
^^^^sweet!^^^^
Has anyone tried Pennzoil ATF? This was recommended by a local Mopar mechanic.
Which Penzoil ATF not Type F I hope or Dex III or VI
USE ANY ATF+4 they all have the same base stocks and the same additive package- you know what your are getting and it's a Type III synthetic and reasonably priced
only better ATF is CITGO QUATRASYN or REDLINE type IV-V based ATF's
Yes, no Type F or Dex. Pennzoil ATF+4 is what I planning on since my flux capacitor's Mr Fusion is in the shop. Thanks
