FOR SALE 440 six pack intake and carbs (orig aluminum)
northerndave
4:24 PM
Minnesota
Hi guys, I accidentally listed this in "performance parts" sorry for the double post.
I may be incorrect on my mopology here so please do correct me if you feel I am misrepresenting.
I have what I understand would be an original aluminum six pack intake for 440, This has the following part number markings.
CHRY 3412046
It does not have the "CH6B" (this seems somewhat important to some people)
Firing order and individual cylinder numbers on each runner.
Dist rotation marking
Carbs are 4394, 4392, 4393
outboard carbs are missing vac actuators.
I also have an air cleaner that goes with it but it's not much good, someone took a grinder to the lip that runs the perimeter of the oval on both lid halves.
Based on the part number, the absence of the CH6B marking, the firing order and dist rotation markings, I am told this is a factory original aluminum intake.
I could toss it in the media cabinet and clean it up, but wanted to list it and show it as I found it.
I'm asking $1200 for it.
I'm in northern MN
Could you post the date codes for the carbs?
Thank you.
D
the center (4392) is 1019, the rear (4394) is 1139, front (4393) is 9829.
I also see that currently the front and rear carbs are not in the right spots, front carb is in the rear spot, rear is on the front spot. not sure why.
I can take pics of codes if you like.
Also it looks like these were for auto trans, I'm sure you guys knew that though.
I noticed that one of the outboard throttle shafts was inserted from the wrong side of the carb. I looked closer and there are no butterflies on that shaft. Also noticed at the same time that the float bowl doesn't look right on that carb, fuel inlet on the wrong side.
With that new info, I'll ship lower 48 for $1000
