The 2330 Hughes is a good cam. A couple of my track buddies ran that cam in their stockish 440. Lew, who posts here, ran that cam in a manifold motor. Maybe he'll post. I think he went 13.0s in a very stock 440 with iron heads on pump gas. In a 440, you can easily run the factory 11" converter.
Like DB stated earlier, when comparing solids to hydraulics, subtract about 8 degrees. Not necessarly exact, but pretty close. So, if you compare the Bullet cam recommendation to the Hughes 2330, they are nearly identical at the valve. The LSA might be different by a couple degrees. And lets be clear, Dave Hughes did not invent the "mopar lobe", and Hughes does not grind cams. The 2330 is an Engle ground cam. Also, the intake lobe spec.ed by Bullet to the OP is for a .904" lobe, but the exhaust lobe is not. But it is a "torque" lobe. I'm sure they did that for reasons I probably cannot comprehend.
The et and mph that I stated earlier comes from personal experiance. Stockish 440, iron head, cast manifolds, 4200 lb car stock converter, 3.23, P235 BFGs, and the MP .455" cam. That cam was 272 advertised and 221 degrees at 0.050". Car went 12.90 at 108 - 109, at 4 different Ohio tracks no less.
