383man
COOL, NICE CAR . Had a 63 once.
Thanks for the kind words. Ron
#27
On the right track on the overlap however at .006 the difference would be more pronounced
You want the overlap to maximize pull on the intake by the exhaust
But not blow your intake out the exhaust
Zoomies, headers, stock exhaust and boat wet exhaust or through the prop are all different
Here's the problem
Flat flank rollers have to start opening the intake “early” inorder to get it open when the piston is moving fast- this gives more overlap than really necessary
Overlap is also a place where long rod/ short rod makes a difference and why stroke and rod length is a necessary parameter
(also needed for that intake close calc discussed last post)
so the exhaust close- intake open points (and the rate if you have time/ duration not having to open As fast as possible) is a design parameter
You do not want the intake to open too early (flow stalls and is late getting going) or too late
unfortunately the trade off to too early opening to get the valve open mid stroke is usually made with the bad idle and fuel economy going out the window acceptable
VVT anyone
Inverse radius cam will increase torque in all ranges
28
Most box cams have narrower LSA and more overlap because they are trying to put 10 pounds of air in a 5 lb sack
VERY rarely does the exhaust need to be higher than the intake- look at your flow charts
Isky hyd grinds are reasonably gentle to be installer forgiving, rev well and low warranties. Want a cam that runs you have to talk to Ron
29 EXACTLY
31 let us know how it turns out and also post in the stroker thread
FWIW I've mostly used Isky lifters. Springs. etc because I had the long deal there
33 I like DP also most of the time, more experience with tunnel ram than single plane but then I have not run low geared no OD street cars in a long time
#36 include Jones on your street roller search- I can vouch that he has rollers that are easy on the valvetrain (and some where you have to change springs on a regular basis) so stay away from rebuild every week race cams on your street car. The Indy buicks had no problem with high rpm valve train stability
37 It can be done if you do not go for a “bottom of the page” grind
