383man
As you discovered power valve should be sized according to your cruise vacuum, not that 'half the idle' BS. You can have the power valve open at idle, and it won't cause your idle to go rich.. You're on the right track going up to the 7.5. The whole idea of the power valve is to be able to run the leanest primary jet you can without stumbles or adverse effects, and then have the extra fuel only when you need it (at throttle time!)
I would step down the primary jet again and see if it cleans up those cruise numbers, because it's easy. If not, time to get inside and tweak the idle/transition circuit. When you say 'fat at light throttle' that's an indicator of too much fuel there. That can get tedious, lots of trial-and-error, but it's so worth it to get the tune spot-on. And FWIW that's usually the area of the carb that needs the most work. Very common. Plenty of help with that here and FABO if you need it.
To answer your last part, don't worry about what the gauge does during decel. As the throttle eases closed vacuum jumps around and pulls extra fuel from the T-slots, as well as what was flowing through the boosters ...but it's temporary. Once you get the cruise area leaned a bit it may help with that too. Gotta tune from the bottom up, and since you posted some different vacuum numbers, is it safe to assume you hooked the gauge where you could read it and went driving? If so....YAY for you! That's a big help when dialing in a carb but many folks don't think about it.
I basically agree with you but you have to be careful how soon the power valve comes in. You dont need it at light part throttle as it should come in on hard throttle when the vacuum drops enough. If you bring it in way to soon and its open at part throttle then it will be to rich at part throttle. And some will then drop the main jet to lean the PT and then it is to lean at WOT. And as you said it can be open at idle and wont cause it to be rich since its only running on the idle circuit and the PV goes into the main circuit. But if you actually have a PV open at idle it will be to rich when you step lightly on the gas. I am just saying that I would not want to bring it on to soon because you need that extra fuel on hard throttle at or close to WOT. If it stumbles at light throttle right off idle I would feel thats more of an Accel pump or timing problem because the PV should not come in until about half throttle or more. And it sounds like he did find an accel pump problem so thats good for him.
Also I hear so many say the DP is no good on the street and thats just not true. I always run a DP on the street and track and they work great. Nothing wrong with a vacuum secondary carb but you can make the DP work very good on the street. Call me an old time racer but I like the DP because when I nail it I like all 4 barrels open right away which you can do with a DP and run great. Good luck with your tuning of it. Ron
