MSD makes a tach adapter for the Gen 3’s. It taps off the #7 coil wire(forget which color) and then you can hook you tach to the wire off the MSD.
Well the tach. is still an issue and sometimes you need to move on to get away from frustrations. So I moved on to my alternator problem, now on my third alternator (thanks goodness for warranties). The new alternators are controlled by the PCM and as soon as I would plug my field (PCM) wires to the alternator you could smell it smoking. Have the main wire going to the starter which is linked to the starter relay which goes to the battery. The gremblems from the old to the new are coming out on this car. It's really neat to have everything power but the old systems weren't designed to handle the power fans, AC, computers, all driven by a 160 amp alternator. - and everything was running through my amp meter which was designed for about 60 amps. More than my alternator was melting - my bulkhead connects were frying and the wires were melting. Good new is I think it is savable. First I need to bypass the amp meter (wanted to keep the dash original - not happening). There is a blog that tell you how to bypass the amp meter;Thanks for your suggestion 5.7. I'am looking at the MSD stuff and there is a bunch. Do you happen to know the number of the tach adapter you have had experience with?
I used the Dakota Digital adaptor for my 6.4 hemi swap. You can set it to work on a bunch of different outputs and inputs. SGI-8Tachometer issues;
Got my fuel issues solved and car is running good. I haven't had much time to work on the RR in a while but tinker when I can. One problem I've run into is my "tic toc" tach. not working and need some help deciding what to do before I throw parts at it. I bought a digital conversion board from "Real Time Engineering", https://www.rt-eng.com/index.php/RTE_67-74_Tach_kit.html This replaces the old analog board (which was fried) to a digital board. It wasn't a piece of cake to install but not bad. Problem is my tach. isn't working. I took the dash panel out again and check everything - seem to be good but tach only flutters when engine is running.
I went back to my engine installation manual and they talk about providing a tach loop with the crate motor wiring harness - which is what I hooked into. The manual also says "The tachometer loop is provided for the user to add an aftermarket tachometer that is made for multiple ignition coils. It does not supply a standard tachometer signal". Bingo. So I call Realtime and told them my problem and ask for suggestions - "Our board was designed to work with the following;
1. Points
2. Electronic Mopar Ignition
3. MSD electronic ignition using the "tach" output from the MSD box (This is a 12V square wave)
4. Pertronix electronic ignition module.
We have no knowledge of the multiple coils type tach signal."
Ok, so the board is providing a "12V square wave" and the tach loop is providing a multi coil signal.
Their has to be some conversion and someone on this forum must of run into this.
I found some stuff on Summit;
https://www.summitracing.com/parts/msd-8920?rrec=true
https://www.summitracing.com/parts/msd-8918?rrec=true
https://www.summitracing.com/parts/atm-9117?rrec=true
https://www.summitracing.com/parts/dak-sgi-8e?rrec=true
I know it’s a big expense but git rid of the old wiring harness. If you have melted some wires that you can see, you probably have some melted you can’t see. All that old wiring is going to give you grief once you start driving it. At the very minimum carry a fire extinguisher!Well the tach. is still an issue and sometimes you need to move on to get away from frustrations. So I moved on to my alternator problem, now on my third alternator (thanks goodness for warranties). The new alternators are controlled by the PCM and as soon as I would plug my field (PCM) wires to the alternator you could smell it smoking. Have the main wire going to the starter which is linked to the starter relay which goes to the battery. The gremblems from the old to the new are coming out on this car. It's really neat to have everything power but the old systems weren't designed to handle the power fans, AC, computers, all driven by a 160 amp alternator. - and everything was running through my amp meter which was designed for about 60 amps. More than my alternator was melting - my bulkhead connects were frying and the wires were melting. Good new is I think it is savable. First I need to bypass the amp meter (wanted to keep the dash original - not happening). There is a blog that tell you how to bypass the amp meter;
https://www.forbbodiesonly.com/moparforum/threads/bulk-head-connectors.177313/
http://www.madelectrical.com/electricaltech/amp-gauges2.shtml
I have it about half done - I think this may solve a lot of problems, especially future ones.
From one frustration to another, but I love it....
First, I called Dakota and talked to their tech support. They don't know if their SGI-8 will do the conversion - they need to know what there products does! Still investigating but thanks for your input Jeff. Question, does the wiring harness on your 6.4 provide a tach. loop?I know it’s a big expense but git rid of the old wiring harness. If you have melted some wires that you can see, you probably have some melted you can’t see. All that old wiring is going to give you grief once you start driving it. At the very minimum carry a fire extinguisher!
Yes I had a tach output on the harness i got from hotwireFirst, I called Dakota and talked to their tech support. They don't know if their SGI-8 will do the conversion - they need to know what there products does! Still investigating but thanks for your input Jeff. Question, does the wiring harness on your 6.4 provide a tach. loop?
Second, I think a fire extinguisher is a good idea in any of these cars - the design is bad. But I think getting rid of the amp meter is definitely a good idea. I hate the idea of adding aftermarket gauges, but the stock ones really do suck. I'll take some pictures of my damage and doing the conversion - will update shortly.
Converting amp to volt meter - wasn't that bad. Started with a cheap volt meter I found on Ebay;
Ripped it apart and ended up with;
Attached it to the old amp meter face with the plastic type screws the came with the new meter. The rivets you drill out won't exactly match so you have to make a little wider space. Doesn't look great with the screws, but when you put the cover back on you won't see them. I thought at this point I may get lucky because the studs extended out the back about an inch - this is good because you won't have to chop up the old bracket that came with the original amp meter. The face plate and new meter is light and shouldn't require much to hold it in the housing.
I drilled two holes in the gauge housing (carefully) and slipped the gauge in. I put shrink wrap on the positive stud and nutted it down with the existing nuts from new gauge (I put a rubber washer to keep the post from shorting to the housing).
Cut an old gauge pin I had and JB'ed it to the pin that came with the new gauge (try not to get JB weld on the pin).
There is only one place I could find a volt gauge facing for rally dash - couldn't find anyone that sells it so I had to make my own. Not done, but it's a close match. I gave my template to a friend who is good with a Circuit machine and he is going to make a dozen. Should have some extras for someone in need.
Going to run a wire from the positive pin to the ignition switch wire. The negative is grounded to the base already.
Other pictures;
Tachometer issues;
1. Points
Tachometer issues;
1. Points
