- 11:18 AM
- Apr 13, 2012
- Granite Bay CA
It looks good enough to have been OEM but I never have seen another one like it.
Timing is everything!You beat me to them by maybe twenty minutes... Good for you! I bought them from Summit the same day... Rowing gears is fun...
Working on the floor? I call that being a floor whore... Bought my lift close to thirty years ago & have zero regrets...
Forgot to mention driveshaft was not included. Steel is $550 from SST and he said about a hundred more for aluminum.Thats not too bad. Maybe 8 years ago or longer I paid $7k for my complete T-56 Magnum from SST. Included everything. Right down to the driveshaft ,clutch ,hydraulic clutch set up, shifter, fabrication template and metal.
Its easier to mount the bellhousing to the trans on the bench to install the hydraulic bearing and the line and the plate. The bellhousing would not install flush to the mounting face of the trans. I used 80 grit Emory cloth to take some aluminum off the hole in the bellhousing to mount flush to the trans. The bearing cushion is specified by SST to be minimum of 1/8 to 3/8 inch.I think you lost me here when you refer to - " Had to take some metal off the bellhousing bore as it would not flush onto the trans. Had to use two 1/4 inch spacers to get the proper bearing cushion" - Could you expand on this explanation please. I'll be doing this conversion myself shortly and am trying to be as prepared as possible for any glitches.
Here a picture of the bellhousing with the section I had to take some off circled in red.Its easier to mount the bellhousing to the trans on the bench to install the hydraulic bearing and the line and the plate. The bellhousing would not install flush to the mounting face of the trans. I used 80 grit Emory cloth to take some aluminum off the hole in the bellhousing to mount flush to the trans. The bearing cushion is specified by SST to be minimum of 1/8 to 3/8 inch. View attachment 1773832
And the bellhousing mounted to the trans afterwards.Here a picture of the bellhousing with the section I had to take some off circled in red.
You are welcome. If you have not read Kerndogs post on his swap I highly suggest you do. He and Coronetdarter have documented the process better than I can. I am just trying to give a total man hour count to do the swap for the first time.Thanks for this. Appreciate it.
