Joe Barnes
Okie
I've read these comments all sounds good but, instead of installing a different cam you could advance your cam 2° which will give you more low end to mid range tourqe. The 383 will respond better even with the 509.
It wasn’t too bad, 60ish at 3k rpm. Had 26” tires so a 28” would’ve helpedCan you drive it on the interstate with those gears?
That camshaft did a really good job in this 400..........Here. you wont be able to brag about your "3/4 race cam" at NAPA, but you will be 100% happier. Sometimes less is more. Duration on a street 383 is one of those times.
https://www.summitracing.com/parts/sum-6400
Do you see there near the bottom of this quote, "no cam recommendations without compression"? Please follow through with that suggestion!Agree with IQ on the previous page
back to basics
what's your compression ratio and cranking compression? did you say what heads
Forget the new converter- gear change etc etc wrong direction 4 U and loose the single plane- good call whoever said it
no mater what the compression that cam (and with that Victor) is a bracket racing cam - not for what you want to do- good combo for a race car
The Comp 268 measured at .006 is about the same as the Stock MOPAR 260 cam or DC 260 cam as far as duration is concerned
why put a chevy cam in your MOPAR? Summit cam (which one) same problem- want cheap get an ELGIN but how to pick?
if low compression even the Comp XE274HL will be too big but may be ok with higher compression much more modern than the 284 MP cam (which also maybe too big in a low compression 383)
Thanks, I remember reading that one a few times. I always enjoyed your dyno threads--they were more 'real-world' and honest than the magazine stuff to me..5 years ago we did a cam swap on a low compression 440 from a Summit 6400 to a 509 camshaft. Here, starting on this page, are some of the dyno results with the cam and other changes we made.
https://www.forbbodiesonly.com/mopa...tarting-on-78-440.58687/page-3#post-909947432
Same cam I run with an old Eddy TM7 Holley 3310 and hedders in a 440. Sounds nice with a mild lope good street manners and decent mileage with 323s. But I am looking for something a little more radical, maybe a step up in the Comp grind or another cam company. Any suggestions are welcome.I was in the same boat as you. I built my 400 with a 509 and a torker intake. After break in, I tried to tune it. Wasn't happening. I tried playing with timing, carb adjustments, even advancing the cam. The max vacuum I could get was 8". I pulled the cam before I even got it on the street and bought a RPM intake and a comp ex268. The engine and I are a lot happier. I'm glad I bit the bullet.
great information thanks, whats your opinions on how those nostalgic guys who run stock exhaust do it without headers?
