1-BAD-B
- 12:13 AM
- Feb 13, 2010
- HUNTINGTOWN, MARYLAND
Hi curious if anyone else has had this problem I have a 6.1 and a tr6060 swapped in a 69 AMX using the factory harness and pcm from a 09 SRT challenger that had a 6.1 and six speed the pcm has had the skim code ( Immobilizer) deleted… I also made sure immobilizer was removed from ignition switch so wouldn’t mess up pcm after skim code was deleted
It won’t start unless I spray starting fluid in throttle body then it starts right up and runs with no issues great throttle response idles great but as soon as I shut it off I have to spray again
Driving me crazy any info would be great I think I’ve messed with it so long I need to step back and see if this has happened to anyone else
Thanks
Thanks
