I've gone through two alternators and voltage regulators so far and the charging system isn't charging. It's eating alternators and I can't figure out why. The field wire from the alternator is going to the FLD post on the regulator. 12v ignition is on the other side. I haven't been able to find where to hot wire on the alternator is going to though. I do know I don't see it going to the battery which I find strange. Then again, I'm new to Mopars. I do remember the regulator that was in the car when I bought it would buzz when you first turn the key. But that's been replaced. The car has a fuel injected 413 with an MSD box and an electronic distributor. I read something briefly about the older regulators not working with electronic ignitions. Is this true? Where is the hot wire from the alternator supposed to go? If someone has a charging system wiring diagram that would be helpful.
A side note, when the car was acting up a few days ago the starter wanted to keep engaging a little after I turned the car off. I know these have a starter relay on the firewall and mine appears to have several things attached to it. Could a bad starter relay or starter have an effect on the charging system?
