33 IMP
- 11:44 AM
- Dec 21, 2017
- taxifornia,soon 2b Arizona.
If you have the original 14" from 62, they will be the big ones.
Well... pewp... thanksIf you have the original 14" from 62, they will be the big ones.
This shifter?62 Dart 440
440 +.030
727 push button converted to B&M floor
ran at Thompson Drag Raceway, late 60’s through 78
Yep, haven't cleaned it up, but mine is for a reverse manual valvebody.Mine looks cleaner, and the sticker is different
62 Dart 440
440 +.030
Any guess to What year this style shifter was made or used it sure looks like a early B-body consol shifter handle
Might have been. As it is for the pushbutton trans, I would guess mid 60s to maybe late seventies? I haven't looked for any kind of manufacture date.Any guess to What year this style shifter was made or used it sure looks like a early B-body consol shifter handle
Did the 394 hp version have solid lifters?According to NHRA the Dodge only was avail with the inline 413, they were rated at 385 or 394, the 394 version had the J heads and 1.74 exhaust valve like the inline 383. They were supposed dealer installed for racing and police work. I have a set of the 3258 and 3259 carbs which show 62 Dodge when specs are found. I have both the low and raised block manis and did quite a bit of testing on the street and strip back in the 80s and 90s.
Yes,.490 lift,the 385 also had the 1.74 exhaust but .431 hydraulic, just checked.Did the 394 hp version have solid lifters?
Here is the setup I put on my 426 Street Wedge in my 1964 Dodge Polara 500 convertible I used to have. I was gifted the carbs by a Corvette friend. They were on the intake he needed for his 1957 2 X 4 283 Corvette motor. I ran the numbers and they came back a I expected: 1962 Chrysler 300H. I had to modify the linkage on the rear carb to accommodate the Dodge throttle cable that pulls the linkage back from above the fulcrum point. The '62 Chrysler has mechanical linkage that pushes the linkage ahead from below the fulcrum point. Classic Industries catalogues a couple of pieces to make the conversion to 2 X 4 inline easier. The carbs also require a spacer under them so carb linkage does not contact intake runners. When asked, I told people that this was an available dealer installed option (wink, wink).
