63 Polara 500 Max Wedge
Yournewtreasureawaits
2:31 PM
Suisun City CA
Does anyone have actual build numbers for the 1963 Polara 500 max wedge cars? I believe to have acquired one. Any help would be appreciated. Thanks!
Welcome YNTA. Congrats on the find and please show so photos / and head over to the welcome wagon for an introduction to the forum .. with more pics
103 hardtops and 28 convertibles. If you post up the vin# it can be looked up to tell if it is a max wedge car and its options.
Thanks for replies. It's a 63' Polara 500, H.C. Max Wedge, I have been told and there is some paperwork stating that there were 7 63' 500's built, 5 L.C. and 2 H.C. The H.C. were 1, 3 speed and 1 auto..
63 Polara 500 H.C. two door hardtop = 7 manual trans. and 12 autos.
Vin will tell you if its stage one or stage two plus options as stated before.
6 H.C. manual stage ones and 11 H.C. auto stage one.
1 H.C. manual and 1 H.C. auto stage 2 were produced according to the book.
What in the VIN would dictate the stage I/Satge II? the build date was 10/62 so I would think it would be a stage I. I would be willing to send you the VIN in a PM if you wouldnt mind helping me out.
Thanks
1 H.C. manual and 1 H.C. auto stage 2 were produced according to the book.[/QUOTE]
Be glad to help. You can PM me if you like. Appears if it was a Oct. 62 there were four cars,two black, one red,and one sandlewood.
Looked again and had to edit. I guess it was to late at night to be reading.
If your build date is in 62, it would be a stage 1, stage 2 was out after may of 63. The serial number will not give the build date. Engine is stamped with date for machining or assembly, I have been told it was after machining. early engines will be month and year, later engines are stamped month, day,and the number that the engine was produced on that day, 01 for first, 02 for second ect. The SO number on the fender tag will tell you the scheduled assembly date, also the radiator support stamp will also..Hope this helps
The pad stamping tells you when the block was machined/assembled. The casting date on the side of the block is just that, the date when the block was cast. The pad stamping date can be a good while after the casting date. On my engine, the casting was Sept 62, the pad stamp is Dec 62.
Anyone have a lower font valance for sale? this car was raced and i spent many many hours removing spotwelds and replacing pieces..making good progress
I have the 63 Dodge book by Darrell Davis that has all the info including the vin's of all the 63 Dodge Max Wedge cars built. I am thinking GoldenCommando has the same book by the info he has given. If not I can look up the vin also and get you the info you need but it sounds like GoldenCommando is taking care of it for you. If I can help with anything just let me know. Oh and we will need pics of the car when you can get them. Good luck , Ron
These are when I started, Ill post some new ones tomorrow
Strange how the area where hood bracing was removed ( at the factory) has rust .As if the bracing was on the hood for a long time and just removed recently?? or maybe it was never painted after brace was removed?
Is it a used hood?
Do you have all the pieces & running gear?
Would love a car exactly like this one ! :blob1:
This is a good I picked up from someone that modified it, the original hood was beyond saving. Everything matched up on the cuts. Ill pot some more, there has been a lot of progress since these were taken. I have 90%, I am missing a few pieces of stainless.
