From an earlier post one had discussed the electric fan arrangement as actually a possible impedance as I was thinking about this setup. Then ya got lots of guys who find they're great. When I reduced the oil weight this was from another concern I had with high oil pressure, then started reading up on oil finding this can be a culprit with higher motor temp. When I reduced it I saw a noticeable change. What a science - engine oil! Motor has to work harder to run heavier weight oil and the heavier visc holds a higher oil temp. Anyway my read up on this found some compelling info I had no clue about. To qualify, most of my drive time though (never much as I'd like) isn't long distances and only occasionally really get on it.Hi Ron, thanks for all the good info.....I'm starting to wonder if the dual electric fans are part of the problem. Once the temp gets up to 180 they come on and don't shut off until 160 which it doesn't get down to and I'm thinking that maybe the fans are not moving as much air at let's say 50mph than if they were shut off and air was just going through the rad on it's own as I go down the road. I had to up the anti-freeze water ratio over last winter due to a cold snap here in Ohio otherwise I run about a 80% water 20% a/f and I also use water wetter but I was having the same issue last year when the ratio was 80-20. I am using a 15W/50 oil called Driven and until I get the temp down I'm going to stay with it.
where in Ohio you live....if close enough maybe we could swap lies some time....lol I live north of Columbus by Delaware
Did you flush the block? What’s the timing?
Well I would have guessed that your fans were pushing air through the rad but you say they are pulling air. I will say from your pitchers that I think you might be onto something with your shroud and fans. Your shroud looks very restrictive and it could be not allowing enough air to flow through the rad on the highway, like fury 64 said path of least resistance.
Thanks! I appreciate your sacrifice.Hey Mike....I hate to say where I got the spring because it was on a Fird website but I guess I can make an exception this time....lol cjponyparts.com but don't tell anyone I'm using a Fird part in my Mopar
