moparmarkk
the change moved the engine back,now later headers and oil pans fit,easier to find and cheaper.Front brake pads can be found at napa stores,Mark
sure did,it was easy.had to turn the trany mount 180,other than that,it was cake,mark
i have a 64 Dodge that is using the Schumaker big block conversion mounts as my car originally had a 318.... i used the Hedman ceramic ones... number 78038 I think... fit good.. no dinging..FWIW i bought these almost 18 years ago so idk if or why they would be shaped different..Hey everybody,
New to the site. This past fall I bought a 64 4 door polara. It's going to be getting swapped to a 440 and some other things. I have done a lot of reading on what to buy and do's and dont's but one thing I'm still unsure of is headers. I've seen some from tti that are made to fit but kinda pricey for my "budget" build. Anybody done this swap and used some cheaper options? Don't have to be the prettiest just work. Thanks
Definitely get a Dakota mini starter.I have a 64 Polara 426 and i went for the Hedman 78030 headers.
I have My heads off so the passenger Side install was a piece of cake, but the driver side is worse. I have removed the starter and i think that if i raise the engine a bit now i Will get it down there.
But i read in this thread the original starter wont work, My car is a 4 speed manual, is the starter the same for automaic cars? Can i also get a Dakota starter? Or maybe a ministarter?
Unless it's an all out effort, I never saw the need to move back the engine 1 5/8".
im building a 64 also how much set back is actually going on if I change my stock k memberHey, gold ain't that ugly!
View attachment 305567View attachment 305568
Rick is right about the extra work, driveshaft and mount. For your 4 door, leaving it the way it is, probably best. You will likely have to cut the right lower corner of your K frame to give you adequate room for your oil pan but that is easy to do.
The newer style K Frame is effective to get your motor back a couple of inches. It's been noted many times in years gone by that a newer K Frame and SS Springs were the hot ticket for these old Mopars. This pic shows you TTI's and the newer style K Frame in place. Note the space at the pan and the K Frame. The collectors sure are positioned nicely on the TTI's. No problem with crazy pipe angles needed to get around the frame. View attachment 305571
View attachment 305567 View attachment 305568 View attachment 305571
It’s years later but I am doing the same thing here in 23 How did yours turn out?Hey everybody,
