65-440
- 6:14 AM
- Dec 2, 2009
- virginia beach, va
Time to sell my '65. Asking $17,000, price negotiable. 446ci., performer rpm heads, the heads were sent to some guy in ct. or ri. and worked but i lost the paperwork and no longer have the specs. performer RPM manifold, Dougs 2" headers, accell billet distributor, MSD 6AL ignition with rev control, taylor 10.5mm wires, alluminum waterpump housing and pump. 160 deg thermostat. just cleaned the radiator out last month. Motor runs VERY strong. 727 built last year. 3800 stall built by dynamic converters, coan super sprag, new drums, clutches, Griner reverse pattern, non-low band apply valve body, dual circuit/ 16 pass trans cooler w/electric fan. 8 3/4 rear. 4.10 gears. brand new clatracs bars, mono-leaf springs.. rancho 5 way adjustable shocks.. all hardware inside drums is new ... front end is solid with a recent re-build, installed caltracs 90/10 shocks the same time that i did the rear... paint is ok, car does need some cowl work .. interior is complete, could use a set of door panels, headliner is mint, floors and trunk are solid..fuel tank has a sump welded in the front, w/ -10an fitting. was going to use that to feed the fuel pump.. im sure im forgetting a whole bunch of stuff ... been down the track a few times, car ran great, high 11's all day long. very consistant. Also very responsive on the street, gets more street time than track time .. having trouble locating all of my pictures, will try and get more tomorrow after work .....
