dvw
It could use more timing. I'm sure it coud use up towards 38 with this head. But it won't quite get there on pump gas. Yes I agree that proper timing could be a lower number with a different combo.. But that would require less compression, larger cam, or more effecient chamber and plug location. This car is a restored stock Coronet R/T convertible. So it has the inefficient 906 head. Did my best to make them as detonation resistant as possible. Pretty hard to get quench with a open chamber cast head. It was supposed to be 9.5-1. But the machinist made an slight error. The owner hates lumpy cams, thus the little cam. Comparing the timing required on big bore old open chamber iron heads with poor chamber design and plug location to modern aluminum small bore stuff is not even on the same page.When it comes to ignition timing less is more. If an engine only wants say 33* advance, then 33*is the right number. Insisting that the engine needs 36-38 is just pushing against the piston in the wrong direction. Anything we can do to increase combustion chamber efficiency, start with a tight quench, then reducing total advance is a win -win situation. Tight quench is an aid to running what maybe a tighter than accepted compression ratio. Sure you can under cam a high compression engine and achieve high cylinder pressures that produce pinging. But why build such an engine and then hamstring it with a tiny cam?
For instance late Ford 302 gt heads. Most engines only wanted 28ish degrees advance. The more efficient the combustion chamber the less advance needed.
Doug
