- 4:33 PM
- Oct 16, 2014
- Salisbury, Vermont
Yes that will work and yes you can cut it 6 inches shorter than your mark. For sure in front of the headlight panel. There is always guys looking for the dog leg section.
I had three passenger side and only one driver side...and of course the driver's side is the best of the bunch.
Actually it could be used as a complete fender if absolutely necessary. Kind of pains me to cut it...
Here's some pics- I marked a line where the 12" from the nose falls in blue sharpie.
I can drill off the headlight buckets to save a little weight.
I also drew arrows pointing to some minor rust. Not in easily seen areas, though.
The 12" mark falls after the headlight support/core support bracket.
Cutting in front of that would save a lot of weight and size.
I'll run shipping both ways with your actual zip when I get home, and pm you those.
