FLY 9999
I have an opportunity of a 383 and 727 from a 1967 Stock Eliminator car. I have a '66 Belvedere and wonder how much do I need to do to get it to look like a '67? THX
With the 67 the 383 combo has one better than the other. TIME TO PONDER!
Same basic body, but there is tons of work and parts needed to make it into a 67.
The whole front clip, as in fenders, grill, headlights, bezels, and front bumper. At the rear tailpannel, taillights and bezels. The trunk lid will have to be redrilled for the correct tailpannel although it would be better to replace it with a 67. They are different. Inside the cluster bezel is different between 66 and 67. There are also different emblems and detail items inside and out. All this is to costly for a 66-67 B body in my opinion.
Seems like a matter of opinion. You did enough get by, whatever inspections were applicable or a inspectors lazy eye. I was trying for a more believable option. In the long run, the VIN tells the difference.not so my fine fathered friend: we changed a 66 satellite to a 67 belvedere gtx /without the gtx badges, back when there was a class diff between them in AHRA...
the tail light housings Dont bolt up the same , I redrilled the holes to fit the 67`s on , the grill can be done the same way ,altho we didn't put all 4 headlights in , only 2 , (weight)...
luckily the cars were the same color of red , nobody knew any dif...
YEP, I'm lost as well...Whaaaaa...??
Have both 66 and 67......wonder if you can interchange the 67 taillight surround along with a 1967 light on 1966....?Are you wanting to race Stock eliminator with your car? I believe the specs are the same on a 66 and 67 383-4 bbl. So you could leave it a 66.
You can't put a 67 trunk panel on a 66 lid. The 67 is concave like the panel is. A 66 trunk is flat, the 67 panel won't go on a 66 lid
Here is a 66 car with a 67 lid and panel. Check the differences. See how much smaller the 66 light are. You will need to cut the holes on the quarter panels bigger for the 67 tail lamps.
Still don't know why you would need to appear to have 67 to run a 383.
The 440 wasn't available in a B body until 1967.
