Gear Dog
New Member
I have to make a very important decision so please help a novice. I will fill you in then you can see the pics. I found a 1967 Plymouth Belvedere GTX for sale that is in immaculate condition. ENGINE: Its had a complete engine and tranny rebuild. its got a 440 that's now .30 over, with 516 heads 78cc and big exhaust valve. Forged pistons, and a Comp Cam Mopar 274/286 .488/.491 Extreme energy camshaft with kit k21-224-4. Springs, lifters, retainers, timing chain, Edelbrock performer dual plane intake. Holley 850 double pumper(rebuilt). A new Accel electronic dist. MSD coil, MSD 6AL. Holley Mechanical fuel pump. Aluminum water pump and housing. A Single wire alternator Chrome powermaster. New Ceramic Hedman Headers, with all new exhaust. New power steering box, and hoses. New brake lines and new fuel lines. Engine has 800 miles since rebuild. Starts up on first try. 60 lbs. oil pressure hot 90 lbs. cold. Runs and sounds great.TRANSMISSION: New B&M Flexplate, B&M 3000 hole shot converter. B&M shift kit not locked out shifts, standard with kick down trans is all new with deep pan. Has Big Driveshaft with NO U joints. REAREND: 8 3/4 rear with 489 case and a 3:23 gear. (NON) Sure Grip. New Gas Tank and sending unit. Now for the car itself. All new chrome trim, inside and out. Car painted 7 yrs ago. All new tires and Magnum 500's. the pics will speak for themselves but they don't do the car justice. This car IS RUST FREE!!! NO RUST ANYWHERE! it was an Arizona car always garage kept. All original metal. Now for some pics. Car Price $23,000 What do u think? Now here is where I need you experts help. Given what you've just seen and read, about the car, what would you still say if I told you the VIN starts with RP, not RS? im the guy who joined this site to find his dad a 67 GTX since a relative wrecked his, in a accident 7 months after he bought it new in 1967. I wanted to do this for my dad for Christmas. every REAL GTX I find on the net in this price range needs a lot of work and the ones that look this good are $60 or higher. I have to let the seller know by tmrw or someone else gets the car. PLEASE HELP!
