roy p
Need help if you can. I know I had labelled everything 15yrs ago but I'm having an issue with hooking up the alternator, it has 2 fields but I'm not sure which wire goes to where. I have a green wire coming off the field side of the voltage regulator but which field does it go to on the alternator? and what about the other field on the alternator I don't see a wire for it. Also would like to know what the Brown wire on the firewall junction box, third horizontal row down and first row across starting from left to right is. In the same horizontal row third from the left is a grey wire that I'm not sure about either. any help would be appreciated. Here is a pic of the carView attachment 218205
