miller
Take a look at your fuse block, should be at the second fuse. But, have you checked ALL the fuses in the block? Test each end of each fuse/wire connector, to be sure.
Yes.Should there be power at the last fuse in block
If your jumping across the flasher, and signal lights work, flasher itself could be bad.If I jump flasher with hot wire were the black wire goes rear signals work from switch,not sure where the power is
Hello trying to get my signal lights working signal light switch replaced also replaced wires running from flasher the black that goes to the last fuse and the red that goes to switch ,I have No power to flasher ???Brake lights ,parking lights work ,Should there be power at the last fuse in block
??If I jump flasher with hot wire were the black wire goes rear signals work from switch,not sure where the power is surprise to come from thanks Gregh
