MCODECUDA
I'll take a look at it sometime this week. There was something that I didn't like about this car when I looked at it some months ago and I think that it may have been the color.
yep ! X2
Not to be an *** but.....
If it's a tribute it should say that.
and he is right a real a12 would fetch much more.
Wrong - from quick glance
paint
wheels
no tach in dash Tach was an option
trunk matt
Wrong air cleaner set up
Colum shift auto should be floor mount hurst ball 4 speed. Why? It's coded as an automatic.
probably more not an a12 expert only a wannabeWrong radiator. Should be an 054. Heater hoses are routed wrong
my 69 has a lift off fiberglass hood does that mean I can call it an a12? No way! I decided to not even call it a tribute since it is so far off. Now I just call mine badass fun.
The fender tag seems suspect for more than just condition. 69 to 71 fender tags start with the engine code. Reading bottom line left to right it should start with e85.
A12 | Chrysler 300-Hpkg 70 only |
The Lynch Road plant used a different layout than other plants. That appears to be a perfectly legit original A12 RR tag. Did it come on this car? I don't know but I see nothing wrong with the tag.
Yep I think that's true.A12s started as 383s, E63 on the fender tag. They were then coverTed to A12S which over rides the E63 on the tag
And that's being kind.
I am taking a closer look at that fender tag and man does it seem way out.
TAKE A GOOD UP CLOSE LOOK I GET THIS. I even found one decoder that says the A12 code can be =
A12 Chrysler 300-Hpkg 70 only
Sales code A12 was used in 1969 for the 6bbl package. For 1970, Sales Code A12 was used for the Chrysler 300. Sales codes changed year to year.
Personally I think the fender tag is wrong the vin looks stamped to match the fender tag like he said the rivets look wrong. Maybe some one else can take a look.
This is pissing me off so much I want to call the cops!:angryfire:
1411 279033 94295111 two digit gate, three digit base, six digit sequence number and the remainder of the VIN: 9A280111
(3)?26 999 93 Engine code 926 B body 383-4BBl Automatic transmission. 999=special axle 93 Automatic transmission behind a 383/440HP
26 A12 26" radiator and A12 sales code package
F3 F4(?) F2X X9 Cant tell either. could be F3 or F8. H2x = black vinyl bench seat interior. X9 inner upper door frames painted black to match interior
X(?)(R?)M21 E(?)63 D32 426 948614 RM21= RR 2Dr coupe. E63=383-4bbl (all A12s code this. They were conversions) D32=Automatic transmission 426= one of two SPDs used for A12 cars. 948614 = VON number
For that money, RC's car would be a better bet.
