Cava3r4
Originally. Car is 1969 Dodge Charger S/E, 383-4bbl, A/C, Auto. Matching numbers.
I bought this car in 1990. In Oct 1993 I got serious about restoring it and I had it on the road in Aug 1994. This is originally a Montana car. It had rust pinholes in the trunk floor (replaced), a pinhole in the right front passenger floor pan (replaced), and the rear valance was all dinged up (Replaced) The right quarter panel had 400 holes in it from some moron with a slide hammer (replaced). All body work was done by B**** Auto Body (Dan Mc****). 2 part epoxy paint and the acid/etch type primer.
I went to school two years to be an "automotive technician" in 1974-5. I made a living turning a wrench for one year. Due to being shot up in vietnam, I could Not physically hack it and went on to be a tool designer and manufacturing engineer for the rest of my life.
The Engine (matching numbers) was rebuilt basically stock. It has the hardened stellite seats pressed into the 906 heads. The heads have been cut .030 to insure flatness. It runs fine on 92 octane unleaded premium gasoline. Valve size is stock. Wolverine brand roller rockers with new melling brand shafts. The kit is Mopar Performance (Mancini Racing), forged 10:1 pistons .030 over.
383 magnum cam, rods were reconditioned (forged) at NAPA. Crank is forged and is .010 under size. Moly rings. Double steel roller timing chain. High Volume oil pump. Windage tray. New Holley replacement carburetor (have original warped one). Mopar performance electronic ignition.
Transmission was rebuilt by Chuck L***** (and it works very nicely). It has a shift kit and a 2400 stall converter. (It will bark the tires on 1-2 shift at part throttle if you want it too)
Rear End is 3.90 gears rebuilt center chuck from Mc****** Racing.
Front end (suspension) is rebuilt using the rubber kit (not the urethane). .020 oversize R/T Torsion bars. R/T rear springs.
Seats are L***** Auto Interior Leather (S/E) faced. I have 6 wheels tires for the car (4 are 245r60-15, 2 are 70 series in the back because 3.90gears are “busy on the freeway”. This has the effect as it would be with stock tires and 3.55 gears. (2700 RPM at 60 instead of 3000 RPM at 60 MPH).
The A/C compressor has been replaced with an S***** unit as I could not get a high pressure hose or compressor that worked. The A/C blows cold and has the new 134 freon replacement in it. I Have the orig parts for the A/C.
The car came with 10 inch drum brakes. I replaced the drums in front with A M***** ***** brand disc brake kit. I have the original parts if you want to go back to those worthless 10 inch drums.
I have an Archive box full of receipts.
I have numerous photos, these are NOT digital but show the car in the body shop with the quarter panel being replaced etc. This is a “very near frame off” job. (If I would have removed the "K frame", it would have been a frame off job)
This has all changed now to below. (the orig 383 is sitting on an engine stand in the garage with matching numbers)
Now... BELOW is what is in the motor.
496/440 stroker motor
250 buying a block / used
2500 buying an Eagle stroker kit Street Rings
1700 edelbrock heads
265 & intake
485 new holley 850 double pumper or a copy of one (grant, etc) WITH Electric Choke (want it "streetable") (replaced this with a thunder series Edelbrock in 2013.)
245 Lunati Voodoo .236/.244 and .500/.513 ? Cam & lifters
USE my Roller rocker arms and melling shafts (if there is NO "step")
125 Gasket set
75 ARP head bolts
75 timing chain with rollers & double sprockets
80 oil pump, hi volume standard pressure
45 hardened oil pump shaft
215 oil pan, 7 QT Minimum
82 windage tray
30 pick up tube, 1/2 in
80 block main stud kit
135 push rods
189 distributor, mopar electronic use my old orange box (now has 6 AL box)
149 alum rocker covers
980 TTI ceramic coated headers, 2 inch into ...
600 $ new H 3 inch pipe.... use dyno max mufflers and tailpipes 3 inch.
100 balancer
70 drive (flex?) plate
140 rear main set (seal?)
99 plug wires for headers
199 $ mini starter
300 Misc, shop rags fluids mounts bolts, belts, sealer, coolant, plugs
800 Machine work
1280 Build time
960 Labor R&R
480 Dress out engine Turqoise complete (intake and heads)
320 install headers
750 Tranny overhaul
$ USE synthetic fluid !! Royal Purple
360 converter
$ 2nd trans cooler "daisy chained" into tranny cooler on the bottom of the radiator and mounted behind grill with hard (steel) lines.
70 new 3/8 fuel line from tank to pump
USE big holley pump that is on the 383 (low mileage)
255 fuel line labor, put inline Napa Gold filter before fuel pump
14613 sub total
7500 down on 6/16/10
7113 projected balance (to this point)
******************************************************REVISION-A
5 Hours plus parts....
1000 New Hood, Painted F-5 Medium Green Metallic (to match car) (I do NOT want the old hood back, but the hood pad and clips I do want do not install the pad though as I may buy a new one if I can't clean the old one)
$ ? >>>Install brake pads provided and cut rotors (minimal cut) to create a more favorable friction surface.
BTW... I want the old motor and parts back (cast headers, etc.)
the drive train has about 7-8 K miles on it since rebuild and it runs STRONG.
3.55 gears in the 8-3/4 number 489 case.
It has 255 x 70 r 15 tires on the back so it computes out to the same as 3.23 gears.
It is within ONE MPH of my wifes new vehicle on the road (speedometer).
The motor was spec'd out copying a friend of mine. He has the same motor in his 68 charger, with 3.23 and automatic. He has run 11.57 at 117 MPH. He also has frame rail connectors (I don't yet) and gumbo tires (I don't yet).
Bob
PS. the Question is "what is it worth? I'm old and am having a hard time getting into and out of it with its bucket seats and console.
PSS the air blows cold!
Car is in Scottsdale, AZ
265 & intake
125 Gasket set
75 ARP head bolts
82 windage tray
135 push rods
100 balancer
199 $ mini starter
800 Machine work
1280 Build time
960 Labor R&R
320 install headers
750 Tranny overhaul
360 converter
14613 sub total
Bob
