Can anybody tell me if it is possible to remove the sump from a 440ci 69 Charger without removing the motor. mine has split and needs to be replaced or welded up
I know it is possible because I did it several times when trying to stop a rear main seal leak years ago. You might have to put a 1.25" socket on the crank pulley bolt to spin the crank a bit.
