70 Charger 500 power window switch
Texas97
4:59 AM
Texas
All, I am having trouble with my rear driver window. i adjusted everything on the stops and it will open and close no problem using the switch in the backseat, but using the master on the driver door, it will only come up a few inches and then stops. also, for some reason, the switch direction is opposite the other three.
Does this signal I just need to rebuild the master switch or is it a ground/relay issue?
Thanks, J
I would check the wiring at the master. Wires might not be in the right cavity. With all the rest working correctly there is no relay or ground causing the issue.
would it be the contacts within the button itself? ill check all connections and make its all there. but it has to get some juice to that wire. maybe the backwards wiring really makes the difference.
thanks, J
@devinism can rebuild your switch, if that turns out to be the problem. If the wiring at the master switch is like my 68 Coronet, it only clips on one way.
