Coelacanth
- 2:14 AM
- May 10, 2024
- Edmonton, Alberta, Canada
So I bought the Moog K7103 offset bushings to get more caster when my car is ready for an alignment. I will also need to remove my UCA's to install new UCA bump stops as mine look like squashed grapes. I was able to remove the old bumpers, but jacking up from the control arms, they don't lift up enough to install the new ones.
I've been doing some reading and found a lot of horror stories discussing installation issues with upper ball joints...control arms stripping out, new ones not threading in, needing to be welded in, etc. I want to keep my original UCA's if possible, as it seems the repops all have fitment issues.
What are your recommendations for safely replacing the upper ball joints? Any part numbers to suggest? I would prefer greaseable ones. I am pretty sure my Charger had the UCA BJ's replaced at least once before, many decades ago. They might actually still be okay, but how best to check the condition? Thanks guys.
