The rest of the patch going in. It's cut oversize and I'm fitting it as I go by using a cut off disc in the grinder.
You can see the strip the cut off disc made. It's pretty easy to work these in like this and you're left with a perfect patch and the perfect gap for welding.
A few more tack welds...
Final trim and tack.... badda boom, badda bing!!
Gaping hole in the side of the tub....
So, I tacked on the part that was cut out and started to work it in the same way.
These tubs are like the bane of my existence, I want them done this way, but I didn't really want to do the work, LOL....
Guess, it's nearly done.
It's like time lapse photography!
Time for a quarter panel fit just to do something besides weld.....
Almost reminds me of a car! With metal!!
After test fitting the right quarter, I noticed that the new AMD tail panel (what else do you call it on a bird?) didn't have the holes for the tail extensions. Luckily, I have an original in the attic. Now, you're probably asking yourself why I have it and it's a good question. I have it for the bonus project. This lowered, drag radial superbird will have it's own trailer to pull on drag week that 's made out of the rear of what else, a Superbird complete with wing!! I have another set of quarter panels in the attic as well as a second set of tail lights for this project. The second wing will really kill the budget!
I tried measuring the original panel to locate the holes, but the AMD and the original were 1/4" off in several dimensions. I had to enlarge a couple of the holes to get the extension to fit. On the other side, I used the one existing hole in the AMD panel and laid the extension on it. I was surprised at the differences between the two panels, even the lock hole was a different diameter!
I marked them and drilled them and this side fit much better.
The panel needs trimmed on both sides as you can see.
But that won't be done until I'm mounting it so I can fit the quarter panel shape to the extension and trim the panel afterwards.
Lol seriously this thing is going to be batsh!t crazy! So excited to watch the project come together, the work you've done already looks outstanding. Man, and I thought my procharged 700 wheel horsepower goal was up there, the 1,800 tt aluminum block hemi is going to be insane lol
And just a though on the fiberglass fenders, completely understand how flimsy feeling they probably are, but given your et goal I bet they'd help out (althought with that much power a couple pounds might not be as noticeable lol). And after tying them into whatever support structure you end up fabricating for the turbos, and possibly adding a couple braces further back I'm sure they'd stiffen up quite a bit. Either way, consider me along for the ride haha
:sixpack:
Glad you like it. It should be very driveable. The cam is a good 12 degrees smaller for this one than my Indy headed 526 hemi in my other car. I checked out your thread, great job on the charger! As for the fenders, the class I want to run at drag week requires an all steel body.
The work looks great. I'll be following this thread.
Thanks, I don't like half assing anything as you well know! Bigal has my old 572 hemi which is what I parted with to help finance this deal. I miss it!! LOL
Well holy ding dang now that's what you call going out of the box. There seems to be a resemblance in the kitty department.
Yours looks bigger and a little more persnickity! :icon_mrgreen:
