The speed that your cranking on this car I don't see you having any problems in meeting your summer 2016 deadline. You're doing magic work here. Looking forward to following along with everyone else. Really eye poppin :icon_cyclops_ani:
Thanks for the kind words, but there's nothing about this car that's magic, lol, but I'm trying to crank along. I'm an unskilled hack when it comes to bodywork! Tonight's update will clearly illustrate that!!
I mentioned earlier that the right side quarter panel wouldn't go up another 1/4" and I'm not one to subscribe to can't or won't so I gave it some persuasion to go up. A floor jack and a 2x4 that fits perfectly into the side marker light opening was enough to do it!
One of the most important tools that I've found when doing this work is as many of these vise grip style clamps as you can possibly buy. I have several of the big 11R clamps, but I find the little 6R's to be of the most use. They seem to get into tighter areas but don't seem to hold as well so more are needed. The other style that would be handy would be some 11SP and 6SP clamps. These are the same but have a swivel pad rather than the small round tip. They would work better at clamping without putting a little dimple into the sheet metal when clamped hard.
The ball peen hammer ranks up there on my 'must have' list for body work but along with the jack and 2x4's just proves what a hack I really am at this!!:violent-smiley-100:
I have in other posts, been a big defender of the AMD sheet metal, and I still am. However, when the trunk extensions are quite a bit longer than the quarter panel and the trunk floor and extend out too far on both ends, you just scratch your head. I'm going to cut this off with the whizz wheel but this photo shows just how much extra is on this end.
Because of the ugly joint between the quarter panel and the trunk extension, it prevented the tail panel from fitting properly as this mock up shows.
I'll finish trimming that joint on both sides, trim up the tail panel a little and then try to get it fitted up next time out. My two hours are up this evening.
ccasion14:
