71 GTX- electronic ignition conversion
71GTXdragpack
11:39 AM
Brampton, Ontario
Hi all,
I'm about to install a Proform electronic distributor and conversion kit on my GTX. I don't want to drill any new holes on my firewall to install the orange box. All the existing holes are used for ballast or voltage regulator etc.
Any recommendations on where? I understand the box needs to be grounded.
thanks for your help!
I made a plate and mounted mine on the rear of the engine for my 71. I ran an additional ground from the mounting bolt to the firewall. You can see it hiding back there.
Been there 2 years no problems. I do keep a spare in the glove box. There is an air gap under the plate as it sits on top of the valley pan hold down. I can get a better pic later.
Here is a shot looking down at it and the plate it self. It's 3/16" flat stock drilled and tapped 1/4"-20 to mount it.
Use a GM HEI 4 pin module, mounted on a heat sink to the dist body. Less wiring, less connections to fail. Switch to an E core coil, which allows removal/bypassing of the bal res. And a spark with more energy, 0.060" plug gaps.....
Info & pics on the web.
Karl, here's a good video for HEI conversion.
thanks buddy! Look forward to seeing you once the car season starts. I bought the Proform conversion kit last year. Was considering adding the Petronix kit instead but was talked out of it due to reliability issues. I really want to keep the stock appearance and get the benefits of electronic ignition.
Way better than the late model "Proform" set ups.
