71 RR frame specs
Lazarus
2:28 PM
Central KY
Hey guys. Evidently I am a search bar idiot because I know I have seen a spec chart on here at one time, but after 2 hours of fruitless searching I cannot find it. I am replacing the front frame rails on a 71 and want to make sure everything is nice and correct. Any help would be appreciated. Btw, I believe the e-bodies are the same from the cowl forward on these cars. Is this correct? Thanks!
Kinda surprised to see zero responses here. That's ok though. I found the specs from an old manual.
Dimensions used to be published in crash books we used back in the 70's and 80's... I still have a few stashed, but I see you got your info. Just make sure you start out level and your control points are correct.
