7072duster
I finally figured out the key has to be on when turning on headlights before the covers will flip up. Well,motor runs but will not rotate the covers is there a source for replacement gears in motor assembly. I assume they were damaged from someone forcing them up cause one side does not go down all the way, twisted rod maybe???. And finally how rare is that headlight option? Thanks
