- 5:13 AM
- Apr 13, 2012
- Granite Bay CA
I am going to keep it wired as shown in the diagram and keep a paper copy in the car, in my FSM and in my car journal.
Nice to see you fixed your problem, even though I don’t fully understand what the problem was. Stock relays didn’t work with Crackedback’s kit, is what I got out of it..
So glad you found the problem. Electrical wiring can be testy for sure. Some times you just have to step back and take a deep breath and then go at it again. One question I have did you do this to take stress off the wiring or to buy pass the old system.
I did it because I wanted to also upgrade to more powerful headlights that would draw more power than these sealed beams. The wire harness on the engine side was new in 2013. The dash side is mostly original and in really nice shape.So glad you found the problem. Electrical wiring can be testy for sure. Some times you just have to step back and take a deep breath and then go at it again. One question I have did you do this to take stress off the wiring or to buy pass the old system.
Yes have run into the same problem with older cars that the wiring and all is old. I agree to take the load off the wiring harness and other part's. If you have all new wiring then it should work fine. But would do this any ways after a while to keep from this problem happening. Thanks for the answer.
That is quite true. Wearing the gloves is a great idea.I don't usually wear gloves but the rumor is that oils from skin or anything can cause the bulbs to fail.
Sweet now you got me to thinking. Yes Halogen bulbs will burn the class where you touch them. Don't touch them with your finger's. You can clean them with rubbing Alcohol. Best to ware clove's. LOL. Hey they are bright enough. Not like the old blubs Hey.I don't usually wear gloves but the rumor is that oils from skin or anything can cause the bulbs to fail. It may be BS, who knows for sure.
Waiting for night time to adjust and report back.
